Changes between Version 6 and Version 7 of BuildingOnMac
- Dec 18, 2014, 7:03:24 AM (9 years ago)
BuildingOnMac
v6 v7 1 1 If all you are looking for are pre-compiled binaries, you can find them in the KyngChaos wiki: 2 2 3 - GDAL 1.9: http://www.kyngchaos.com/files/software/frameworks/GDAL_Complete-1.9.dmg [[BR]] 4 - GDAL 1.8: http://www.kyngchaos.com/files/software/frameworks/GDAL_Complete-1.8.dmg [[BR]] 3 Last version of GDAL: http://www.kyngchaos.com/software/frameworks#gdal_complete 5 4 6 7 If you are looking to build GDAL, you have various options. Here are two: 5 But if you need to build GDAL, you have various options. Here are two: 8 6 9 7 '''The Homebrew way''' … … 17 15 This will bring any dependencies necessary (PROJ/GEOS/etc) with it, download them and install them. 18 16 19 If you want to compile the trunk version of GDAL instead, you can use the following command instead:17 If you want to compile the trunk version of GDAL instead, you can use the following command: 20 18 {{{ 21 19 brew install gdal --HEAD 22 20 }}} 23 21 24 If you want to Compile and Debug using XCode use brew to install gdal, then follow the instructions to setup XCode from here:22 If you want to Compile and Debug using XCode, use brew to install gdal, then follow the instructions to setup XCode from here: 25 23 26 24 http://blog.burhum.com/post/35555678746/debugging-makefile-based-projects-using-xcode-gdal-as
