Changes between Version 28 and Version 29 of Buildbot
- Mar 24, 2018, 11:40:03 AM (6 years ago)
Buildbot
v28 v29 17 17 * Builds with a rich set of dependencies 18 18 19 A [https://travis-ci.org/#!/OSGeo/gdal/builds Travis-CI] instance has been [http ://svn.osgeo.org/gdal/trunk/.travis.yml configured] to build GDAL and run of the Java, Perl and Python tests for each SVN commit in trunk. For that, [https://github.com/OSGeo/gdal a git clone of GDAL] is regularly synchronized with SVN.19 A [https://travis-ci.org/#!/OSGeo/gdal/builds Travis-CI] instance has been [https://github.com/OSGeo/gdal/blob/master/.travis.yml configured] to build GDAL and run of the Java, Perl and Python tests for each git commit in the master branch. 20 20 21 21 [https://github.com/rouault/gdal_coverage Another github repository] is slightly modified to generate coverage information from the run of the GDAL autotest suite. The results are available [http://rawgithub.com/rouault/gdalautotest-coverage-results/master/coverage_html/index.html here].
