Changes between Version 26 and Version 27 of Buildbot
- Jan 19, 2016, 2:43:47 PM (8 years ago)
Buildbot
v26 v27 8 8 9 9 There is also a Appveyor continuous integration build. It builds a minimal GDAL (no optional dependency) in DEBUG mode with Visual Studio 2008 (aka VC9 / MSVC 1500), 2013 (a.k.a VC12 / MSVC 1800) and VS 2015 (a.k.a VC13 / MSVC 1900), so as to fit below the 30 minutes limit. The builds can be see at : 10 https://ci.appveyor.com/project/rouault/gdal-coverage . Note that the Python autotest suite is not run due to the timeout issue.10 https://ci.appveyor.com/project/rouault/gdal-coverage . The Python autotest suite is run. 11 11 12 12 Travis-CI builds with mingw and mingw-w64 are also available : see trunk_mingw and trunk_mingw_w64 builds at https://travis-ci.org/rouault/gdal_coverage/builds . They include just Proj 4.8.0 as a dependency, and run the autotest suite with Python under Wine
