149 | | ||'''NCML type definition'''||'''NetCDF Type'''|| |
150 | | ||short||NC_SHORT|| |
151 | | ||int||NC_INT|| |
152 | | ||float||NC_FLOAT|| |
153 | | ||double||NC_DOUBLE|| |
154 | | ||String||NetCDF Text|| |
155 | | * When translating between ADAGUC NetCDF4 files the metadata attribute types are kept. (Everything was converted to strings in V0.1) |
| 149 | ||'''NCML type definition'''||'''NetCDF Type'''||'''GDAL metadata prefix'''|| |
| 150 | ||String||NetCDF Text||[C]|| |
| 151 | ||short||NC_SHORT||[S]|| |
| 152 | ||int||NC_INT||[I]|| |
| 153 | ||float||NC_FLOAT||[F]|| |
| 154 | ||double||NC_DOUBLE||[D]|| |
| 155 | |
| 156 | * When translating between ADAGUC NetCDF4 files the metadata attribute types are kept. The GDAL API is used to pass metadata in the form of Strings between drivers. Inside the ADAGUC NetCDF driver the metadata has the form of "NO2#[C]long_name=Nitrogen Dioxide". In this case the attribute 'long_name' with value 'Nitrogen Dioxide' is put as string to variable 'NO2'. '[C]' indicates that the metadata type is a String. |
