Changes between Version 10 and Version 11 of ADAGUC
- Aug 22, 2008, 6:09:05 AM (16 years ago)
ADAGUC
v10 v11 89 89 == Sample ADAGUC files == 90 90 [[http://geoservices.knmi.nl/testfiles/ADAGUC_sample_test_files.zip This zip file] contains a folder with sample ADAGUC files. The folder contains two different datasets. The first contains Sciamachy level 3 tropospheric NO2 measurements obtained from http://www.temis.nl. The second file contains precipitation radar data from the Royal Dutch Meteorological Institute (KNMI, http://www.knmi.nl). The radar dataset has been resampled to 256x256 pixels to make it suitable for this example. The radar dataset contains 24 Radar precipitation images with 5 minute interval ranging from 2008-07-20 00:00:00 till 2008-07-201 01:55:00. This radar dataset is included purely to demonstrate the use of the time dimension. The file is created from a source ADAGUC NetCDF4 file (not included). When translating from an ADAGUC file all time dimensions with corresponding units are copied. It is also possible to subset time by using the select band option -b. Multiple bands can be selected. A single image can also be opened by using ADAGUC:filename.nc:varname.nc:dimname=value, e.g. ADAGUC:RADAR_EXP.NC:NL25_PCP:time=45 91 The first NO2 dataset is fully ADAGUC compliant and contains metadata obtained from the NCML file METANCML=SCIA__TEST_R___TMTNO2__L3.xml91 The first NO2 dataset is fully ADAGUC compliant and contains metadata obtained from the NCML file. 92 92 ---- 93 93 == gdal commands ==
