Changes between Initial Version and Version 1 of 2009_ESRI_Merge
May 27, 2009, 7:36:20 PM (15 years ago)
warmerdam
  • 2009_ESRI_Merge
     1= 1.6 ESRI to Trunk Merge =
     3This page attempts to track efforts to merge ESRI local changes from the http://svn.osgeo.org/gdal/sandbox/warmerdam/1.6-esri branch into 1.7 trunk circa May 2009.  The changes mostly appeared in r17058.
     5== Deferred ==
     7{{{
     8
     91.6-esri/gdal/frmts/hdf4/hdf4dataset.cpp (modified) (18 diffs)
     101.6-esri/gdal/frmts/hdf4/hdf4dataset.h (modified) (2 diffs)
     111.6-esri/gdal/frmts/hdf4/hdf4imagedataset.cpp (modified) (19 diffs)
     121.6-esri/gdal/frmts/hdf4/makefile.vc (modified) (1 diff)
     13  - The changes are many.  It appears ESRI folked the HDF4 driver around
     14    1.5.0 or so, and many modern (1.6) changes are missing and they have
     15    done quite a few things themselves.
     16
     171.6-esri/gdal/gcore/gdalrasterband.cpp (modified) (1 diff)
     18  - Changes in GetHistogram() approximation - I don't understand the rationale.
     19
     201.6-esri/gdal/ogr/ogr_core.h (modified) (3 diffs)
     21  - Stuff about _ESRI_WKB - I dont understand it.
     231.6-esri/gdal/frmts/gtiff/gt_wkt_srs.cpp (modified) (22 diffs)
     241.6-esri/gdal/ogr/ogr_fromepsg.cpp (modified) (1 diff)
     251.6-esri/gdal/ogr/ogr_spatialref.h (modified) (1 diff)
     261.6-esri/gdal/ogr/ogr_srs_api.h (modified) (5 diffs)
     271.6-esri/gdal/ogr/ogr_srs_esri.cpp (modified) (15 diffs)
     281.6-esri/gdal/ogr/ogr_srsnode.cpp (modified) (1 diff)
     291.6-esri/gdal/ogr/ogrspatialreference.cpp (modified) (3 diffs)
     30  - Major overhaul - much of this has already been incorporated but we
     31    ought to do further review.
     32
     331.6-esri/gdal/frmts/bsb/bsbdataset.cpp (modified) (5 diffs)
     34  - Various messy changes, not necessarily suitable for trunk.  Some of
     35    these have already been backported from trunk.
     36
     371.6-esri/gdal/frmts/gtiff/libgeotiff/geo_new.c (modified) (1 diff)
     38  - This seems to relate to handling missing or NULL ascii key values but
     39    I don't understand it at all.
     40
     411.6-esri/gdal/gcore/gdaldefaultoverviews.cpp (modified) (2 diffs)
     42  - Something specific was changed here instead of leaving things as they
     43    were after r16419 but I don't know the rationale.
     44
     451.6-esri/gdal/frmts/hfa/hfa.h (modified) (1 diff)
     461.6-esri/gdal/frmts/hfa/hfaband.cpp (modified) (20 diffs)
     471.6-esri/gdal/frmts/hfa/hfacompress.cpp (modified) (1 diff)
     481.6-esri/gdal/frmts/hfa/hfafield.cpp (modified) (1 diff)
     491.6-esri/gdal/frmts/hfa/hfaopen.cpp (modified) (10 diffs)
     501.6-esri/gdal/frmts/hfa/hfatype.cpp (modified) (6 diffs)
     51  - Lots of changes, many of which require some explanation.
     52  - Includes NullBlock() support (missing blocks with nodata value).
     53}}}
     54
     55== Processed ==
     56
     57{{{
     58
     591.6-esri/gdal/data/gdal_datum.csv (modified) (10 diffs)
     60  - Some stuff like "Not specifed (based on...)" altered - ignored.
     61  - Added some ESRI datum name equivelents in libgeotiff (r1580).
     62
     631.6-esri/gdal/frmts/bmp/bmpdataset.cpp (modified) (2 diffs)
     64  - Ignored the portion in IReadBlock().  A bunch of error reporting code
     65    during io was replaced by memset(0) on failure - I don't know why.
     66  - transferred logic that sets BMP resolution in geotransform (r17065)
     67
     681.6-esri/gdal/frmts/ecw/ecwdataset.cpp (modified) (5 diffs)
     69  - Several diffs appear to be just white space.
     70  - GetProjectionRef() now lets PAM override internal info, but this
     71    change has been recoded to avoid possibility of returning NULL.
     72  - GetGeoTransform() now returns the PAM geotransform if there is any
     73    reason to believe we have overridden with the PAM projection.  This
     74    is also coded differently than originally, hopefully to a similar effect.
     75  - Changes applied in trunk (r17066, r17067)
     76
     771.6-esri/gdal/gcore/overview.cpp (modified) (1 diff)
     78  - Fix leak if overview generation interrupted.  Ported by Even (r17078).
     79
     801.6-esri/gdal/frmts/gif/gifdataset.cpp (modified) (14 diffs)
     81  - Most changes were already backported from trunk.
     82  - Incorporated change to ensure world file is only written in CreateCopy
     83    if the source dataset has a geotransform (r?????)
     84
     851.6-esri/gdal/frmts/hdf5/hdf5dataset.cpp (modified) (1 diff)
     86  - The change in 1.6-esri was to set the subdataset metadata on the dataset
     87    if there were at least two subdatasets.  I'm not sure why this was not
     88    done if there was only one subdataset.   I suspect the core change is
     89    due to ArcGIS using GetMetadataItem() while the HDF5Dataset was only
     90    overriding GetMetadata() for subdatasets.
     91  - In trunk I changed to store subdatasets on the base dataset, dropping
     92    the GetMetadata() override which was done poorly.
     93  - I also added code similar to HDF4 to directly open single subdataset
     94    files via HDF5ImageDataset class from HDF4Dataset::Open(). (r17081)
     95
     961.6-esri/gdal/frmts/jp2kak/jp2kakdataset.cpp (modified) (4 diffs)
     97  - Datatype/scaling changes ignored, mostly better in trunk already.
     98  - Added worldfile reading if all else fails.
     99  - Added logic to limit tiles to 64K due to jpeg2000 limitation.
     100  - Changes are in r17085.
     101
     1021.6-esri/gdal/frmts/jpeg/jpgdataset.cpp (modified) (2 diffs)
     103  - Support .jpw world file - not standard naming (r17087)
     104
     1051.6-esri/gdal/frmts/mrsid/mrsiddataset.cpp (modified) (6 diffs)
     106  - Ensure PAM mechanism supported for nodata values.
     107  - Ensure PAM mechanism can be used to override SRS/Geotransform.
     108  - Add MG version to metadata.
     109  - Avoid capturing large binary metadata.
     110  - Changes in trunk (r17089, r17093, r17096).
     111
     1121.6-esri/gdal/frmts/pcidsk/gdal_pcidsk.h (modified) (2 diffs)
     1131.6-esri/gdal/frmts/pcidsk/pcidskdataset.cpp (modified) (8 diffs)
     114  - Even's changes from r16171 were accidentally discarded (ignored)
     115  - Added worldfile reading.
     116  - Added PAM fallback for geotransform.
     117  - Added support for default overviews (ie. .ovr or .rrd).
     118  - Changes in trunk (r17097)
     119
     1201.6-esri/gdal/frmts/raw/btdataset.cpp (modified) (3 diffs)
     121  - Derive from pam already in trunk.
     122  - Other changes seem incoherent.
     123
     1241.6-esri/gdal/frmts/png/pngdataset.cpp (modified) (1 diff)
     125  - Only write world file if src has geotransform (r17116)
     126
     1271.6-esri/gdal/frmts/raw/landataset.cpp (modified) (3 diffs)
     128  - Give preferences to PAM coordinate system.
     129  - Fallback to PAM geotransform.
     130  - The implementation in trunk (r17117) is quite different than esri branch
     131    but should hopefully achieve the same thing.
     132
     1331.6-esri/gdal/frmts/dted/dteddataset.cpp (modified) (7 diffs)
     134  - Give precidence to .aux.xml or .aux for srs (r17118).
     135
     1361.6-esri/gdal/frmts/ers/ersdataset.cpp (modified) (2 diffs)
     137  - Give precidence to .aux.xml or .aux for srs (r17119).
     138
     1391.6-esri/gdal/frmts/raw/ehdrdataset.cpp (modified) (16 diffs)
     140  - Add support for update .clr (color table) files.
     141  - Add support for .flt (32bit float) files.  (r17120)
     142
     1431.6-esri/gdal/gcore/gdal_misc.cpp (modified) (3 diffs)
     144  - Support reading world files with blank lines (r17121)
     145
     1461.6-esri/gdal/gcore/gdalpamdataset.cpp (modified) (1 diff)
     147  - This change (add aux to file list) was regressed again in r17068.
     148  - So, no action required.
     149
     1501.6-esri/gdal/frmts/gtiff/geotiff.cpp (modified) (32 diffs)
     151  - 1.6-esri missing r16987, backported in r17135.
     152  - Changes to not have colortables on one bit color tables - ignored.  This
     153    will result in inappropriate display characteristics in other apps.
     154  - Change to make WORLDFILE=YES to tfw instead of wld - ignored.
     155  - slightly alternate logic with regard to using GCPs, but I don't understand
     156    the rationale - ignored.
     157  - where world files searched for changed, don't know why - ignored.
     158  - bIsXML setting location different for no apparent reason - ignored.
     159  - Changes with regard to bigtiff sizes appears to already match trunk.
     160  - SPARSE_OK defaults to TRUE instead of FALSE, no idea why - ignored.
     161  - NBITS set for GTiffOddBits - incorporated.
     162  - YCbCr JPEG added as a compression type - incorporated.
     163  - generate MINISWHITE IMAGESTRUCTURE metadata item - incorporated.
     164  - Set missing blocks to the nodata value if there is one - incorporated,
     165    but without the implicit nodata value of 1 when NBITS=1.
     166  - Changes incorporated in trunk as r17137.
     167
     1681.6-esri/gdal/gcore/gdaldataset.cpp (modified) (2 diffs)
     169  - GDALDumpOpenDatasetsForeach() change was a missing patch since 1.6.1RC1,
     170    fixed in 1.6-esri branch (r17138).
     171  - GetFileList() checks for world files (incorporated, r17140).
     172
     1731.6-esri/gdal/frmts/nitf/nitfdataset.cpp (modified) (11 diffs)
     174  - Added support for unpacking a variety of pixel depths, incorporated
     175    in trunk as r17141.
     176  - Care taken to not loose Even's size validation code.
     177
     1781.6-esri/gdal/frmts/nitf/nitfimage.c (modified) (4 diffs)
     179  - Added support for reading odd numbers of bit data.
     180  - Fix for flipped GCPs in some cases.
     181  - Incorporated in trunk as r17142.
     182}}}
     183
     184== Ignored ==
     185
     186{{{
     187
     1881.6-esri/gdal/makefile.vc (modified) (3 diffs)
     1891.6-esri/gdal/nmake.opt (modified) (17 diffs)
     190  - Wide variety of changes - likely not suitable for mainline.
     191
     1921.6-esri/gdal/apps/makefile.vc  (modified)  (3 diffs)
     193  - accidental removal of gdalbuildvrt.
     194
     1951.6-esri/gdal/data/esri_extra.wkt (modified) (1 diff)
     196  - added 31491-31495 but these already existing in EPSG resources.
     197
     1981.6-esri/gdal/frmts/nitf/makefile.vc (modified) (1 diff)
     1991.6-esri/gdal/frmts/mrsid/makefile.vc (modified) (1 diff)
     2001.6-esri/gdal/ogr/wcts/makefile.vc (modified) (1 diff)
     2011.6-esri/gdal/pymod/makefile.vc (modified) (1 diff)
     2021.6-esri/gdal/swig/csharp/makefile.vc (modified) (2 diffs)
     2031.6-esri/gdal/swig/java/makefile.vc (modified) (1 diff)
     2041.6-esri/gdal/vb6/makefile.vc (modified) (1 diff)
     2051.6-esri/gdal/ogr/ogrsf_frmts/oci/makefile.vc (modified) (1 diff)
     206  - Changes related to more than one build target.
     207
     2081.6-esri/gdal/frmts/gdalallregister.cpp (modified) (7 diffs)
     209  - I don't see any particular pattern to the rearrangement done here.
     210
     2111.6-esri/gdal/frmts/hdf4/hdf-eos/makefile.vc (modified) (1 diff)
     212  - -D_HDFDLL_ is passed in HDF4_FLAGS, but I'm not sure why - ignoring for now
     213
     2141.6-esri/gdal/frmts/jp2kak/makefile.vc (modified) (1 diff)
     215  - Adds CORESYS_IMPORTS and KDU_AUX_IMPORTS to defines, not sure why.
     216
     2171.6-esri/gdal/frmts/makefile.vc (modified) (2 diffs)
     218  - ESRI specific format selection.
     219
     2201.6-esri/gdal/frmts/raw/idadataset.cpp (modified) (2 diffs)
     221  - Adjust precision of Clarke 1866 ellipsoid.  I don't know what the
     222    justification is for this, so I'm avoiding it.  The value currently
     223    used seems to be much closer to the value I compute than the value
     224    in the esri branch.
     225
     2261.6-esri/gdal/frmts/gtiff/libgeotiff/geo_normalize.c (modified) (4 diffs)
     227  - Changes the order of preference when searching for Albers/Equidistant
     228    NatOriginLong to give preference to ProjCenterLongGeoKey over
     229    ProjNatOriginLongGeoKey.  I cannot imagine cases in which there is a
     230    conflict so I see no point in incorporating this.
     231  - There is a bunch of stuff related to introducing invFlattening into the
     232    definition, but I believe this was already incorporated into trunk in
     233    such a way that no changes in libgeotiff were required.
     234  - Logic to use already found datum or ellipsoid but this code does not seem
     235    to do anything since GTIFKeyGet does not alter the value argument if the
     236    key is not found.
     237}}}
