Changes between Version 2 and Version 5 of Ticket #7106
- Oct 23, 2017, 6:44:03 AM (6 years ago)
Ticket #7106 – Description
v2 v5 21 21 Without the OCS normal vector, there is not enough information for an application to recreate the block insertion properly. 22 22 23 This patch stores the OCS in a new "BlockOCS " field.23 This patch stores the OCS in a new "BlockOCSNormal" field. 24 24 25 The patch also changes the location of an INSERT entity with DXF_INLINE_BLOCKS set to false to be in the OCS... this is less than ideal for end users, but it is essential to preserve proper read/write round-tripping of DXF files. Alternative suggestions would be welcomed.25 ~~The patch also changes the location of an INSERT entity with DXF_INLINE_BLOCKS set to false to be in the OCS... this is less than ideal for end users, but it is essential to preserve proper read/write round-tripping of DXF files. Alternative suggestions would be welcomed.~~ this is no longer the case, I added the "BlockOCSCoords" field to solve this problem. 26 26 27 27 == Issue 4: INSERT entities are incorrectly merged into a GeometryCollection when DXF_INLINE_BLOCKS is false
