Changes between Initial Version and Version 1 of Ticket #7032
Sep 7, 2017, 8:54:49 AM (7 years ago)
cmartinez
  • Ticket #7032 – Description
    initial v1
    11When loading a layer on PostGIS using ogr2ogr, a sequence is created for the serial primary key.
    2 If -preserve_fid paramenter is provided, the sequence start is not properly initialized (i. e. sequence starts on 1). This leads to problems if the layer is later edited. Is this an intended behaviour or should be considered a bug?
     2If -preserve_fid paramenter is provided, the sequence start is not properly initialized (i. e. sequence starts on 1). This leads to problems if the layer is later edited.
    44Note that I am using GDAL version 1.11.3.
