Changes between Initial Version and Version 1 of Ticket #6680
- Oct 12, 2016, 8:33:34 PM (8 years ago)
Ticket #6680 – Description
initial v1 18 18 2: Chart1 (None) 19 19 }}} 20 note that I cannot access Sheet2 without modifying the document to re-order the tabs so that it is before "Chart1". And if I blank the data from Sheet two, "Chart1" no longer is listed (and I'm not sure why -- I can add this as a separate .xlsx file if needed).20 note that I cannot access Sheet2 without modifying the document to re-order the tabs so that it is before "Chart1". And if I blank the data from "Sheet2", "Chart1" no longer is listed (and I'm not sure why -- I can add this as a separate .xlsx file if needed). 21 21 22 An expected would only read the spreadsheet tabs, skipping any Charts:22 An expected behaviour would only read the spreadsheet tabs, skipping any Charts: 23 23 {{{ 24 24 1: Sheet1 (None)
