Changes between Initial Version and Version 1 of Ticket #6590
- Jul 11, 2016, 6:46:45 PM (8 years ago)
Ticket #6590 – Description
initial v1 3 3 What I know for sure is that qhull has a header file called io.h, which is also distributed as part of mingw. In my case, it is located under <prefix>/x86_64-w64-mingw32/include, for 64-bit, and <prefix>/i686-w64-mingw32/include, for 32-bit). 4 4 5 This effectively makes the compilation fail, as the io.h file from qhull does not define some symbols needed by GDAL.5 This effectively makes the compilation fail, as the io.h file from qhull is chosen to be included instead and it does not define some symbols needed by GDAL.
