Changes between Initial Version and Version 1 of Ticket #6399
- Mar 4, 2016, 6:20:16 AM (8 years ago)
Ticket #6399 – Description
initial v1 1 There w as a buffer overflow bug in pre-2.0.2 versions of gdal, which has been corrected in #6256. The correction was to truncate the amount of bytes read to that of the buffer. This resulted in non-functional (but secure) code.1 There were potential buffer overflows in pre-2.0 versions of gdal, which have been corrected in [32027] and later changesets. The correction was to truncate the amount of bytes read to that of the buffer. This resulted in non-functional (but secure) code. 2 2 3 3 Here we introduce another buffer variable with the correct size to read the full EOL label. 4 5 There are also other minor corrections in the patch, as well as a new label entry to let the user know that the driver is handling the #5941 bug correctly.
