Changes between Initial Version and Version 3 of Ticket #6269
- Dec 30, 2015, 7:10:00 AM (8 years ago)
Ticket #6269 – Description
initial v3 21 21 Attached you will find the `Makefile` I use to generate them. 22 22 23 But then my problems arrive. The Python2 script (a heavily modified version https://github.com/StyXman/elevation/blob/ master/generate_tiles.py of OSM's `generate-tiles.py`) uses threads for rendering, and I'm using 4 in my 4-core machine.23 But then my problems arrive. The Python2 script (a heavily modified version https://github.com/StyXman/elevation/blob/3b3f530c050f57b0fdf40a975805a96a6c376288/generate_tiles.py of OSM's `generate-tiles.py`) uses threads for rendering, and I'm using 4 in my 4-core machine. 24 24 25 25 When the script starts using the VRT files (from zoom level 7; before, the small versions were used), it starts complaining about problems reading individual files. The files in particular are not always the same, and they have been regenerated just in case. The complaints stated being like this:
