Changes between Initial Version and Version 3 of Ticket #5852
Feb 21, 2015, 12:34:32 PM (9 years ago)
Bas Couwenberg
Replying to martinl:
@sebastic: could you please try attachment:gdal-grass-configure.patch instead of your version?
Thanks for your patch, it looks like a much better way to support future GRASS 7 versions.
I've included your patch in the Debian package for the GDAL GRASS plugin and the resulting build with GRASS 7.0.0 looks good.
  • Ticket #5852
    • Property Cc martinl added
  • Ticket #5852 – Description
    initial v3
    44
    55The attached patch fixes both issue. The .table files are copied conditionally, and a second check for the final GRASS 7.0.0 library is added in case 7.0 SVN was not found.
     7I've attached an updated version of my patch to only change the Makefile.in to support both paths for the .table files.
