Changes between Initial Version and Version 1 of Ticket #5070
- May 3, 2013, 10:44:37 AM (11 years ago)
Ticket #5070 – Description
initial v1 1 I've researched and it appears that buildvrt is supposed to be able to resolve overlap areas when no data values are defined , but I am unable to produce the expected results.1 I've researched and it appears that buildvrt is supposed to be able to resolve overlap areas when no data values are defined for the sources, but I am unable to produce the expected results. 2 2 3 3 I've tried the following workflow:
