Changes between Initial Version and Version 2 of Ticket #4739
- Aug 3, 2012, 2:41:27 AM (12 years ago)
Ticket #4739 – Description
initial v2 5 5 [http://webhelp.esri.com/arcims/9.3/general/mergedprojects/arcxmlguide/elements/shapeworkspace.htm SHAPEWORKSPACE - ArcXML Programmer's Reference] 6 6 7 When the dataset that has non-zero LDID not corresponding to encoding of the table contents will be used, the user have to set correct LDID with binary editor beforehand. Otherwise the user have to set zero to LDID by saving with OpenOffice.org Calc and create cpg file with any text editor. Compared to them, it's easier to add a cpg file to the dataset created with LDID/0 as a default.7 In the first case, when the dataset that has non-zero LDID not corresponding to encoding of the table contents will be used, the user have to set correct LDID with binary editor beforehand. Otherwise the user have to set zero to LDID by saving with OpenOffice.org Calc and create cpg file with any text editor. Compared to them, it's easier to add a cpg file to the dataset created with LDID/0 as a default. 8 8 9 9 Therefore, I think that LDID/0 will be more appropriate than LDID/87 as a default.
