| 15 | |
| 16 | Hi, |
| 17 | |
| 18 | I was not able to email the file to you. The message to trac@osgeo.org bounced back. |
| 19 | |
| 20 | I did try your suggestion and it did fix the problem. All 37 data sets were found. Thanks for getting back so quickly on this. |
| 21 | |
| 22 | This work is for the MultiSpec project that I have: https://engineering.purdue.edu/~biehl/MultiSpec/ |
| 23 | |
| 24 | You can download the grib file from the site that I got it from: |
| 25 | |
| 26 | http://mirador.gsfc.nasa.gov/cgi-bin/mirador/granlist.pl?page=1&location=(-90,-180),(90,180)&dataSet=NLDAS_MOS0125_H&version=002&allversion=002&startTime=2007-06-30T00:00:01Z&endTime=2007-06-30T23:59:59Z&keyword=NLDAS_MOS0125_H&longname=NLDAS%20Mosaic%20Land%20Surface%20Model%20L4%20Hourly%200.125%20x%200.125%20degree%20&CGISESSID=4d4f18008ca17bbabc634c2fe9914553&prodpg=http://mirador.gsfc.nasa.gov/collections/NLDAS_MOS0125_H__002.shtml |
| 27 | |
| 28 | Select NLDAS_MOS0125_H.A20070630.1700.002.grb file. It downloads with a name of Unknown for me. You can rename it to the name given above. |
| 29 | |
| 30 | Let me know if there are questions. |
| 31 | |
| 32 | |
| 33 | |
| 34 | - Larry |
