Changes between Version 1 and Version 2 of Ticket #4603
- Apr 5, 2012, 8:32:43 PM (12 years ago)
Ticket #4603
- Property Keywords grib added; grb files removed
- Property Status new → assigned
- Property Component default → GDAL_Raster
Ticket #4603 – Description
v1 v2 2 2 A character is read from the grib file apparently to test whether it is at the end of the file. EOF is returned if there is an error in reading a character. But if the character read in the file is equal to EOF, the reading of valid data stops. I have a NLDAP grib file with 37 data sets in it. It stop after 9 because a character read with this routine happens to be -1. I did a check of chData to see if it was equal to EOF and set chData to 0 instead. The grib file was read correctly. I was able to access all 37 data sets. Is there a reason for chData at this point to indicate a badly formed grib file if the value return here is -1? 3 3 4 {{{ 4 5 int FileDataSource::DataSourceFgetc() 5 6 { … … 11 12 return EOF; 12 13 } 14 }}}
