Changes between Initial Version and Version 4 of Ticket #430
- Dec 22, 2007, 4:33:22 AM (16 years ago)
Ticket #430
- Property Cc added
Ticket #430 – Description
initial v4 1 {{{2 1 Andrey, 3 2 4 Steve Soule from Vexcel has pointed me to an ASTER HDF file which seems 5 to have incorrect georeferencing. He raised the concern because the 6 georeferencing didn't match a GeoTIFF file derived from the file by other 7 software. I confirmed this, and noticed that the lat/long corners of the 8 image as reported in the metadata don't seem to match the lat/long corners 9 reported after reprojection (in the gdalinfo report). 3 Steve Soule from Vexcel has pointed me to an ASTER HDF file which seems to have incorrect georeferencing. He raised the concern because the georeferencing didn't match a GeoTIFF file derived from the file by other software. 10 4 11 I will attach the gdalinfo report to this bug report. The file itself is12 pretty large so I am putting it putting it at the following url for download, 13 assuming you need to do that.5 I confirmed this, and noticed that the lat/long corners of the image as reported in the metadata don't seem to match the lat/long corners reported after reprojection (in the gdalinfo report). 6 7 I will attach the gdalinfo report to this bug report. The file itself is pretty large so I am putting it putting it at the following url for download, assuming you need to do that. 14 8 15 9 http://pobox.com/~warmerdam/ASTER_DEM20020123085409.hdf 16 }}}
