Changes between Initial Version and Version 2 of Ticket #3952
Feb 8, 2011, 1:58:54 PM (13 years ago)
rolker
Thanks for applying the patch. I was going to ask if the build instructions should go on the wiki or in a README file, but you answered that! I created http://trac.osgeo.org/gdal/wiki/BuildingForAndroid with the original instructions.
  • Ticket #3952
    • Property Milestone 1.8.11.9.0
  • Ticket #3952 – Description
    initial v2
    11I'm creating this ticket to collect patches and procedures for building GDAL for the Android platform.
    3 == Building GDAL using Android NDK ==
    5 This procedure was developed on a Linux system using Android NDK r5b.
    7 First, a standalone toolchain is created to make the configure script easier to use. (See android-ndk-r5b/docs/STANDALONE-TOOLCHAIN.html for more details)
    8
    9 {{{
    10 ~$ android-ndk-r5b/build/tools/make-standalone-toolchain.sh --platform=android-8 --install-dir=android-8-toolchain
    11 }}}
    12
    13 Next, the toolchain's bin directory is added to the PATH.
    14
    15 {{{
    16 ~$ export PATH=$PATH:~/android-8-toolchain/bin/
    17 }}}
    18
    19 From the GDAL source directory, configure for cross compiling and make.
    20
    21 {{{
    22 gdal$ CC="arm-linux-androideabi-gcc" CXX="arm-linux-androideabi-g++" \
    23 CFLAGS="-mthumb" CXXFLAGS="-mthumb" LIBS="-lsupc++ -lstdc++"  ./configure --host=arm-linux-eabi --without-grib
    24 gdal$ make
    25 }}}
    27 == Next steps ==
    28
    29  * check if resulting libs are usable.
    30  * build and adapt the Java swig bindings to expose GDAL to the Java portion of an Android application.
     3Instructions for building can be found at http://trac.osgeo.org/gdal/wiki/BuildingForAndroid
