Changes between Initial Version and Version 1 of Ticket #3711
- Aug 4, 2010, 8:28:56 PM (14 years ago)
Ticket #3711 – Description
initial v1 1 I use GDAL Java API to write raster data to Oracle Spatial GeoRaster Object, and encouter a strange problem: 1 I use GDAL Java API to write raster data to Oracle Spatial GeoRaster Object, and encouter a strange problem:[[BR]] 2 2 3 " 3 4 # 4 # A fatal error has been detected by the Java Runtime Environment: 5 # A fatal error has been detected by the Java Runtime Environment:[[BR]] 6 5 7 # 6 # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0afa0770, pid=5904, tid=5548 8 # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0afa0770,pid=5904, tid=5548[[BR]] 9 7 10 # 8 # JRE version: 6.0_15-b03 9 # Java VM: Java HotSpot(TM) Client VM (14.1-b02 mixed mode windows-x86 ) 10 # Problematic frame: 11 # C [gdal17.dll+0x190770] 11 # JRE version: 6.0_15-b03[[BR]] 12 13 # Java VM: Java HotSpot(TM) Client VM (14.1-b02 mixed mode windows-x86 )[[BR]] 14 15 # Problematic frame:[[BR]] 16 17 # C [gdal17.dll+0x190770][[BR]] 18 12 19 # 13 20 # An error report file with more information is saved as: 14 # D:\workspace\GDALTest\hs_err_pid5904.log 21 # D:\workspace\GDALTest\hs_err_pid5904.log[[BR]] 22 15 23 # 16 24 # If you would like to submit a bug report, please visit: 17 # http://java.sun.com/webapps/bugreport/crash.jsp 18 # The crash happened outside the Java Virtual Machine in native code. 19 " 25 # http://java.sun.com/webapps/bugreport/crash.jsp[[BR]] 26 27 # The crash happened outside the Java Virtual Machine in native code.[[BR]] 28 29 "[[BR]] 30 20 31 This is my Java codes: 21 import org.gdal.gdal.gdal; 22 import org.gdal.gdalconst.gdalconstConstants; 32 33 {{{ 34 import java.nio.ByteBuffer; 35 23 36 import org.gdal.gdal.Band; 24 37 import org.gdal.gdal.Dataset; 25 38 import org.gdal.gdal.Driver; 39 import org.gdal.gdal.gdal; 40 import org.gdal.gdalconst.gdalconstConstants; 26 41 27 import java.nio.ByteBuffer;28 42 29 public class GDALTest 1{43 public class GDALTest3 { 30 44 31 /**32 * @param args33 */34 45 public static void main(String[] args) { 46 47 Dataset dataset1; 48 Dataset dataset2; 35 49 36 Dataset Dataset1; 37 Dataset Dataset2; 38 Band Band1; 39 Band Band2; 50 Band band1; 51 Band band2; 52 53 Driver driver; 54 40 55 gdal.AllRegister(); 41 Dataset1 = gdal.Open("georaster:georaster/georaster@localhost:1521/orcl,rdt_2,0"); 42 Dataset2 = gdal.Open("georaster:georaster/georaster@localhost:1521/orcl,rdt_2,0", 43 gdalconstConstants.GA_Update); 44 Band1 = Dataset1.GetRasterBand(1); 45 Band2 = Dataset2.GetRasterBand(1); 46 Dataset2.SetProjection(Dataset1.GetProjection()); 47 Dataset2.SetGeoTransform(Dataset1.GetGeoTransform()); 48 System.out.println("Passing information from input dataset to output dataset"); 49 int XSize = 100; 50 ByteBuffer buffer = ByteBuffer.allocateDirect(XSize); 51 buffer = Band1.ReadRaster_Direct(0,0,XSize,1); 52 Band2.WriteRaster_Direct(0,0,XSize,1,buffer); 53 Dataset2.FlushCache(); 54 System.out.println(buffer.getLong()); 55 Dataset1.delete(); 56 Dataset2.delete(); 56 57 driver = gdal.GetDriverByName("georaster"); 58 59 dataset1 = gdal.Open("geor:georaster/georaster@orcl,rdt_01,1"); 60 band1 = dataset1.GetRasterBand(1); 61 62 int xSize = dataset1.getRasterXSize(); 63 int ySize = dataset1.getRasterYSize(); 64 int bands = dataset1.getRasterCount(); 65 66 String options[] = new String[]{"INSERT=VALUES(103, 'new.tif', SDO_GEOR.INIT('rdt_01',3))", "BLOCKXSIZE=512", "BLOCKYSIZE=512"}; 67 dataset2 = driver.Create("georaster:georaster/georaster,,georaster_table,georaster", 68 xSize, ySize, bands, band1.getDataType(), options); 69 70 dataset2.SetGeoTransform(dataset1.GetGeoTransform()); 71 dataset2.SetProjection(dataset1.GetProjection()); 72 73 band2 = dataset2.GetRasterBand(1); 74 75 ByteBuffer buffer = ByteBuffer.allocateDirect(xSize); 76 77 for( int i =0; i < ySize; i++ ) { 78 79 buffer = band1.ReadRaster_Direct(0,i,xSize,1); 80 81 band2.WriteRaster_Direct(0,i,xSize,1,buffer); 82 } 83 84 dataset2.FlushCache(); 85 86 System.out.println("generate a new georaster : " + dataset2.GetDescription()); 87 88 dataset1.delete(); 89 dataset2.delete(); 57 90 } 58 91 59 92 } 93 }}} 94 95 60 96 61 97 When executing the sentence "Dataset2.FlushCache();", the above problem rises. 62 98 63 The exact error report is attached. 99 By the way, I can use gdal_translate to load GTiff file to Oracle Georaster database successfully, and I can also export Oracle Spatial GeoRaster data to GTiff file with GDAL Java API. But why can't I use GDAL Java API to load GTiff file to Oracle GeoRaster database? 100 101 The version of GDAL is 1.7.1, and it is compiled with Visual Studio 2008. The GTiff image is 183MB with 3 bands. 102 103 The log of exact error is attached.
