Changes between Initial Version and Version 1 of Ticket #3174
Oct 7, 2009, 8:57:31 AM (15 years ago)
warmerdam
Julien,
Do you have any, hopefully modestly sized and public examples of this data we could use for testing?
  • Ticket #3174
    • Property Status newassigned
    • Property Component defaultGDAL_Raster
    • Property Priority highestnormal
    • Property Milestone 1.6.31.7.0
    • Property Keywords driver removed
  • Ticket #3174 – Description
    initial v1
    11When trying to read complex data with envi header using gdal 1.6.2, the following error occurs:
     2{{{
    33ERROR 1: The file does not have a value for the data type
    44that is recognised by the GDAL ENVI driver.
     5}}}
    66This come from the following commented lines (frmts/raw/envidataset.cpp:1791):
     7{{{
    88/*  Removed JBP, ITT-VIS 11/29/2007.  Complex data does not display
    99properly in the ArcGIS application so we are removing it from the
    1919            break;
    2020*/
    21
    22 No wonder why I can not use my dataset anymore. I must say that I'm very surprised that every gdal users looses a valuable (SAR users will agree for sure) supported dataset types just to accomodate one software which is not able to display complex data.
     21}}}
     22No wonder why I can not use my dataset anymore. I must say that I'm very surprised that every gdal users looses a valuable (SAR users will agree for sure) supported dataset types just to accommodate one software which is not able to display complex data.
