Changes between Initial Version and Version 2 of Ticket #1321
- Mar 26, 2007, 9:26:03 PM (17 years ago)
Ticket #1321
- Property Cc added
- Property Owner changed from to
- Property Milestone → 1.4.1
- Property Priority high → normal
Ticket #1321 – Description
initial v2 1 {{{ 1 2 2 e-mail conversation 3 3 … … 6 6 I am trying to access an ODBC database using the ogr virtual layer access (using shp2img). The layer seems to be defined properly as far as I know. It looks something like : 7 7 8 {{{ 8 9 ... 9 10 CONNECTION "<OGRVRTDataSource> … … 17 18 </OGRVRTLayer> 18 19 </OGRVRTDataSource>" 20 }}} 19 21 20 22 The error message is the following : 21 23 24 {{{ 22 25 msOGRFileNextShape(): OGR error. Attempt to use STRING field `Longitude' with numeric comparison `>'. <br> 23 26 … … 30 33 <GeometryField encoding='PointFromColumns' x='Longitude' y='Latitude'/> 31 34 35 }}} 32 36 33 37 Frank's last e-mail … … 49 53 database you are using and the SQL declaration for the field in that database 50 54 I can try and get this fixed sooner or later. 51 }}}
