Changes between Version 1 and Version 2 of WikiStart
Mar 6, 2008, 1:06:44 PM (16 years ago)
jfournier
  • WikiStart
    v1 v2
    1 = Welcome to Trac 0.10.3.1 =
     1= Fusion =
    3 Trac is a '''minimalistic''' approach to '''web-based''' management of
    4 '''software projects'''. Its goal is to simplify effective tracking and handling of software issues, enhancements and overall progress.
    6 All aspects of Trac have been designed with the single goal to
    7 '''help developers write great software''' while '''staying out of the way'''
    8 and imposing as little as possible on a team's established process and
    9 culture.
    10
    11 As all Wiki pages, this page is editable, this means that you can
    12 modify the contents of this page simply by using your
    13 web-browser. Simply click on the "Edit this page" link at the bottom
    14 of the page. WikiFormatting will give you a detailed description of
    15 available Wiki formatting commands.
    16
    17 "[wiki:TracAdmin trac-admin] ''yourenvdir'' initenv" created
    18 a new Trac environment, containing a default set of wiki pages and some sample
    19 data. This newly created environment also contains
    20 [wiki:TracGuide documentation] to help you get started with your project.
    21
    22 You can use [wiki:TracAdmin trac-admin] to configure
    23 [http://trac.edgewall.org/ Trac] to better fit your project, especially in
    24 regard to ''components'', ''versions'' and ''milestones''.
    25
    27 TracGuide is a good place to start.
    28
    29 Enjoy! [[BR]]
    30 ''The Trac Team''
     3Fusion is a web-mapping application development framework for MapGuide OS and MapServer built primarily in JavaScript.  It allows non-spatial web developers to build rich mapping applications quickly and easily.  Using widgets, developers are able to add, remove, or modify functionality using standard-compliant HTML and CSS.  Fusion does not require any proprietary browser plug-ins and works in all the major browsers on Windows, Mac, and Linux.
    314
    325== Starting Points ==
    336
    34  * TracGuide --  Built-in Documentation
    35  * [http://trac.edgewall.org/ The Trac project] -- Trac Open Source Project
    36  * [http://trac.edgewall.org/wiki/TracFaq Trac FAQ] -- Frequently Asked Questions
    37  * TracSupport --  Trac Support
     7 * GetIt -- Download Fusion Binaries for MapGuide OS and MapServer
     8 * Support -- Get support for Fusion
     9 * Documentation
     10 * FAQ -- Frequently Asked Questions
     11 * Contributing
     12 * Filing Bugs and Requests
     13 * Fusion PSC
     14 * Licensing
    3815
    39 For a complete list of local wiki pages, see TitleIndex.
     16For a complete list of Fusion wiki pages, see TitleIndex.
