| 1 | [[PageOutline]] |
| 2 | [[BR]] |
| 3 | || '''Automatically generated page, do not modify. User Notes can be created at: [wiki:Widgets/ViewSizeUsageNotes]'''|| |
| 4 | [[BR]] |
| 5 | |
| 6 | = Widget: ViewSize = |
| 7 | |
| 8 | Display the size of the current view in user-definable units |
| 9 | |
| 10 | == Usage Notes == |
| 11 | |
| 12 | See: [wiki:Widgets/ViewSizeUsageNotes] |
| 13 | |
| 14 | == Common Widget Properties == |
| 15 | |
| 16 | * '''Location''' : |
| 17 | * '''Label''' : ViewSize |
| 18 | * '''Tooltip''' : The size of the map |
| 19 | * '''StatusText''' : |
| 20 | * '''ImageUrl''' : |
| 21 | * '''ImageClass''' : |
| 22 | * '''StandardUi''' : false |
| 23 | * '''ContainableBy''' : Splitterbar |
| 24 | |
| 25 | == Parameters == |
| 26 | |
| 27 | === Units === |
| 28 | |
| 29 | * '''Description''' : the units to display the size in |
| 30 | * '''Type''' : String |
| 31 | * '''Label''' : Units |
| 32 | * '''Meters''' ''(Label: Meters)'' |
| 33 | * '''Kilometers''' ''(Label: Kilometers)'' |
| 34 | * '''Feet''' ''(Label: Feet)'' |
| 35 | * '''Yards''' ''(Label: Yards)'' |
| 36 | * '''Miles''' ''(Label: Miles)'' |
| 37 | * '''Degrees''' ''(Label: Degrees)'' |
| 38 | * '''Pixels''' ''(Label: Pixels)'' |
| 39 | * '''DefaultValue''' : Meters |
| 40 | * '''IsMandatory''' : false |
| 41 | |
| 42 | === Precision === |
| 43 | |
| 44 | * '''Description''' : Precision of the size displayed |
| 45 | * '''Type''' : integer |
| 46 | * '''Label''' : DistancePrecision |
| 47 | * '''Min''' : -1 |
| 48 | * '''Max''' : 6 |
| 49 | * '''DefaultValue''' : 2 |
| 50 | * '''IsMandatory''' : false |
| 51 | |
| 52 | === Template === |
| 53 | |
| 54 | * '''Description''' : A template string to display the size. Values in {} will be replaced by actual values |
| 55 | * '''Type''' : String |
| 56 | * '''Label''' : Template |
| 57 | * '''DefaultValue''' : {w} x {h} {units} |
| 58 | * '''IsMandatory''' : false |
| 59 | |
