| 1 | [[PageOutline]] |
| 2 | [[BR]] |
| 3 | || '''Automatically generated page, do not modify. User Notes can be created at: [wiki:Widgets/MaptipUsageNotes]'''|| |
| 4 | [[BR]] |
| 5 | |
| 6 | = Widget: Maptip = |
| 7 | |
| 8 | A widget to display information about features under the mouse as it hovers over the map |
| 9 | |
| 10 | == Usage Notes == |
| 11 | |
| 12 | See: [wiki:Widgets/MaptipUsageNotes] |
| 13 | |
| 14 | == Common Widget Properties == |
| 15 | |
| 16 | * '''Location''' : |
| 17 | * '''Label''' : Map tip |
| 18 | * '''Tooltip''' : |
| 19 | * '''StatusText''' : |
| 20 | * '''ImageUrl''' : |
| 21 | * '''ImageClass''' : |
| 22 | * '''StandardUi''' : false |
| 23 | * '''ContainableBy''' : |
| 24 | |
| 25 | == Parameters == |
| 26 | |
| 27 | === Delay === |
| 28 | |
| 29 | * '''Description''' : The delay in milliseconds before showing a map tip |
| 30 | * '''Type''' : integer |
| 31 | * '''Label''' : Delay |
| 32 | * '''Min''' : 0 |
| 33 | * '''Max''' : 10000 |
| 34 | * '''DefaultValue''' : 350 |
| 35 | * '''IsMandatory''' : false |
| 36 | |
| 37 | === Layer === |
| 38 | |
| 39 | * '''Description''' : The layers to display information about |
| 40 | * '''Type''' : String |
| 41 | * '''Label''' : Layers |
| 42 | * '''IsMandatory''' : false |
| 43 | |
| 44 | === Tolerance === |
| 45 | |
| 46 | * '''Description''' : The number of screen pixels around the cursor to query |
| 47 | * '''Type''' : integer |
| 48 | * '''Label''' : Tolerance |
| 49 | * '''Min''' : 0 |
| 50 | * '''Max''' : 10 |
| 51 | * '''DefaultValue''' : 2 |
| 52 | * '''IsMandatory''' : false |
| 53 | |
| 54 | === Target === |
| 55 | |
| 56 | * '''Label''' : Target |
| 57 | * '''Type''' : String |
| 58 | * '''Description''' : The frame, window, or TaskPane in which to open hyperlinks. If empty, a new window is used |
| 59 | * '''IsMandatory''' : false |
| 60 | * '''DefaultValue''' : MaptipWindow |
| 61 | |
| 62 | === WinFeatures === |
| 63 | |
| 64 | * '''Label''' : Window Features |
| 65 | * '''Type''' : String |
| 66 | * '''Description''' : Options for opening hyperlinks new window, if used |
| 67 | * '''IsMandatory''' : false |
| 68 | * '''DefaultValue''' : menubar=no,location=no,resizable=no,status=no |
| 69 | |
