Changes between Initial Version and Version 1 of TracSyntaxColoring
Mar 6, 2008, 11:07:29 AM (16 years ago)
  • TracSyntaxColoring
     1= Syntax Coloring of Source Code =
     2Trac supports language-specific syntax highlighting of source code in [wiki:WikiFormatting wiki formatted] text and the [wiki:TracBrowser repository browser].
     4To do this, Trac uses external libraries with support for a great number of programming languages.
     6Currently Trac supports syntax coloring using one or more of the following packages:
     8 * [http://www.codento.com/people/mtr/genscript/ GNU Enscript]
     9 * [http://silvercity.sourceforge.net/ SilverCity]
     10
     11To activate syntax coloring, simply install either one (or more) of these packages. No additional configuration is required, however to modify the colors, have a look at `trac/htdocs/css/code.css`.
     12
     13When in use, Trac will automatically prioritize !SilverCity highlighting over Enscript if possible, (see note below).
     14
     15If neither package is available, Trac will display the data as plain text.
     16
     17'''Note:''' Enscript supports a greater number of languages, however !SilverCity is generally faster since it is a library and isn't executed in an external process.
     18
     19=== About SilverCity ===
     20!SilverCity uses the lexer from [http://www.scintilla.org/ Scintilla]. Scintilla supports more languages than !SilverCity implements. If you want to add a language to !SilverCity supported by Scintilla, it's not very difficult. See [http://projects.edgewall.com/trac/wiki/SilverCityAddLanguage SilverCityAddLanguage] for some information how.
     21
     23== Syntax Coloring Support ==
     25|| || !SilverCity || Enscript ||
     26|| Ada      ||   || X ||
     27|| Asm      ||   || X ||
     28|| * ASP    || X || X ||
     29|| * C      || X || X ||
     30|| * C#     ||   || X(2) ||
     31|| * C++    || X || X ||
     32|| * Java   ||   || X ||
     33|| Awk      ||   || X ||
     34|| CSS      || X ||   ||
     35|| Diff     ||   || X ||
     36|| Eiffel   ||   || X ||
     37|| Elisp    ||   || X ||
     38|| Fortran  ||   || X ||
     39|| Haskell  ||   || X ||
     40|| HTML     || X || X ||
     41|| IDL      ||   || X ||
     42|| Javascript || X || X ||
     43|| m4       ||   || X ||
     44|| Makefile ||   || X ||
     45|| Matlab   ||   || X ||
     46|| Objective-C|| || X ||
     47|| Pascal   ||   || X ||
     48|| * Perl   || X || X ||
     49|| * PHP    || X || X ||
     50|| PSP      || X ||   ||
     51|| Pyrex    ||   || X ||
     52|| * Python || X || X ||
     53|| * Ruby   || X || X (1) ||
     54|| Scheme   ||   || X ||
     55|| Shell    ||   || X ||
     56|| SQL      || X || X ||
     57|| Troff    ||   || X ||
     58|| TCL      ||   || X ||
     59|| Tex      ||   || X ||
     60|| Verilog  ||   || X ||
     61|| VHDL     ||   || X ||
     62|| Visual Basic |||| X ||
     63|| VRML     ||   || X ||
     64|| XML      || X ||  ||
     65
     66''(*) Supported as inline code blocks in [wiki:WikiFormatting Wiki text] using WikiProcessors.''
     67
     68''(1) Ruby highlighting is not included in the Enscript distribution.  Highlighting rules for Ruby can be obtained from: http://neugierig.org/software/ruby/
     69
     70''(2) C# highlighting is not included in the Enscript distribution.  Highlighting rules for C# can be obtained from: http://wiki.hasno.info/index.php/Csharp.st
     71
     72== Extra Software ==
     73 * GNU Enscript -- http://directory.fsf.org/GNU/enscript.html
     74 * GNU Enscript for Windows -- http://gnuwin32.sourceforge.net/packages/enscript.htm
     75 * !SilverCity -- http://silvercity.sf.net/
     76
     77----
     78See also: WikiProcessors, WikiFormatting, TracWiki, TracBrowser
