Changes between Version 12 and Version 13 of MapGuideCommercialOverlays
- Jul 22, 2009, 10:57:28 AM (15 years ago)
v12 v13 151 151 <isBaseLayer>false</isBaseLayer> 152 152 <useOverlay>true</useOverlay> 153 <projection>EPSG:900913</projection> 153 154 </Options> 154 155 <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan-m.MapDefinition</ResourceId> … … 158 159 }}} 159 160 160 '' Note that the commercial layer must be the base layer so any overlays must have the isBaseLayer: false option set. You can also161 '' Note that the commercial layer must be the base layer so any overlays must have the isBaseLayer: false option set. The projection tag is needed so that OpenLayers will initialize the layer in the same projection as the base map. You can also 161 162 pass other [http://openlayers.org/ OpenLayers] layer options in the Options tag. For example, <opacity>0.8</opacity> creates a semi-transparent appearance.'' 162 163
