Changes between Initial Version and Version 1 of LinkSVNToTrac
Mar 26, 2008, 8:27:35 AM (16 years ago)
wbronsema
  • LinkSVNToTrac
     1= Updating Trac Tickets Automatically from SVN Commit Messages =
     3A special '''post-commit''' hook in SVN searches commit messages for text in the form of:
     5 * command #1
     6 * command #1, #2
     7 * command #1 & #2
     8 * command #1 and #2
     10Instead of the short-hand syntax "#1", "ticket:1" can be used as well, e.g.:
     11 * command ticket:1
     12 * command ticket:1, ticket:2
     13 * command ticket:1 & ticket:2
     14 * command ticket:1 and ticket:2
     15
     16In addition, the ':' character can be omitted and issue or bug can be used
     17instead of ticket.
     18
     19You can have more then one command in a message. The following commands
     20are supported. There is more then one spelling for each command, to make
     21this as user-friendly as possible.
     23 close, closed, closes, fix, fixed, fixes::
     24    The specified issue numbers are closed with the contents of this
     25    commit message being added to it.
     26 references, refs, addresses, re, see::
     27    The specified issue numbers are left in their current status, but
     28    the contents of this commit message are added to their notes.
     29
     30A fairly complicated example of what you can do is with a commit message
     31of:
     32
     33   Changed blah and foo to do this or that. Fixes #10 and #12, and refs #12.
     34
     35This will close #10 and #12, and add a note to #12.
