Changes between Version 4 and Version 5 of FusionInstallationConfiguration
- Oct 27, 2008, 7:36:20 AM (15 years ago)
v4 v5 6 6 1. Download the latest binary archive from http://trac.osgeo.org/fusion. 7 7 1. Unzip the archive into your !MapGuideOpenSource\!WebServerExtensions\www directory. If you selected the default location for !MapGuide Open Source during installation this will likely be located in C:\Program Files. Please refer to the 'Configuration' section below for further instruction if you did not install !MapGuide Open Source in the default location. 8 1. Copy the file fusion/config_dist.json to fusion/config.json and modify the settings for your system configuration if required .8 1. Copy the file fusion/config_dist.json to fusion/config.json and modify the settings for your system configuration if required (v1.1 and later). 9 9 1. View your installation by navigating to http://localhost:8008/mapguide/fusion/samples/mapguide/. Port 8008 is the default port used by !MapGuide Open Source. 10 10 … … 12 12 1. Download the latest binary archive from http://trac.osgeo.org/fusion. 13 13 1. Unzip the archive into your /usr/local/MapGuideOpenSource/www directory. 14 1. Copy the file fusion/config_dist.json to fusion/config.json and modify the settings for your system configuration if required .14 1. Copy the file fusion/config_dist.json to fusion/config.json and modify the settings for your system configuration if required (v1.1 and later). 15 15 1. View your installation by navigating to http://localhost:8008/mapguide/fusion/samples/mapguide/. Port 8008 is the default port used by !MapGuide Open Source. 16 16
