Changes between Version 9 and Version 10 of DevelopersCorner
Mar 6, 2008, 5:03:46 PM (16 years ago)
pagameba
  • DevelopersCorner
    v9 v10
    1111  This is the main development area for Fusion and is always the most up-to-date version.  It will typically be somewhat unstable and should not be used for deploying applications.
    1212'''branches''':
    13   Releases of Fusion are organized into branches.  When a new major or minor release is made, it is copied from trunk to the branches folder and named {{{fusion-<major>-<minor>}}}.  Any bug fixes related to that version are applied to the branch and new bugfix releases can be created from the branch from time to time.  A branch is considered stable and usable for deploying applications.
     13  Releases of Fusion are organized into branches.  When a new major or minor release is made, it is copied from trunk to the branches folder and named {{{fusion-<major>.<minor>}}}.  Any bug fixes related to that version are applied to the branch and new bugfix releases can be created from the branch from time to time.  A branch is considered stable and usable for deploying applications.
    1414'''tags''':
    15   All major, minor and bugfix releases of Fusion are tagged by copying the appropriate branch revision to the tags folder.  Binary releases are created by checking out a tag sub folder and running the build process against that folder.  You should not commit any changes to a tag.
     15  All major, minor and bugfix releases of Fusion are tagged by copying the appropriate branch revision to the tags folder and named {{{fusion-<major>.<minor>.<bugfix>}}}.  Binary releases are created by checking out a tag sub folder and running the build process against that folder.  You should not commit any changes to a tag.
    1616'''sandbox''':
    1717  Everyone who is a Fusion developer should have a sandbox folder to use for testing out new ideas and implementing specific functionality.  Sandbox directories can be used for anything you like.
    1919=== Using SVN ===
    2020
     21To check out a copy of '''trunk''', a branch, a tagged version, or a sandbox, you need to know the ''URL'' and use {{{svn checkout <url>}}}.  For instance:
     23 * {{{svn co http://svn.osgeo.org/fusion/trunk}}} - check out trunk
     24 * {{{svn co http://svn.osgeo.org/fusion/branches/fusion-1.0}}} - check out the branch for version 1.0
     25 * {{{svn co http://svn.osgeo.org/fusion/tags/fusion-1.0.0}}} - check out the 1.0.0 released version
     26 * {{{svn co http://svn.osgeo.org/fusion/sandbox/pagameba}}} - check out pagameba's sandbox
     27
     28Once you have a checked out copy, this is called a working copy.  To update a working copy to the latest version, you use the ''update'' command with no arguments:
     29
     30 * {{{svn update}}}
     31
     32To move the working copy to a specific revision number, you can add the ''revision'' parameter:
     34 * {{{svn update -r <revision>}}}
     35
     36To see if you have changes in your working copy against the current revision:
     37
     38 * {{{svn status}}}
     39
     40To see the differences between your working copy and the current revision:
     41
     42 * {{{svn diff}}}
     43 * {{{svn diff > diff.patch}}} redirects the output to a file that is suitable for using with the {{{patch}}} command
     44
    2145== The Build Process ==
    2246
