Changes between Initial Version and Version 1 of CreatingPatches
Mar 8, 2008, 4:57:35 AM (16 years ago)
pagameba
  • CreatingPatches
     1= How to Create a Patch =
     3If you have a patch that you wish to be included in the Fusion repository, this is what you need to do:
     5 * '''File a Ticket:''' No patches will be made to trunk unless they are accompanied by a trac ticket. For complete instructions:  [wiki:FilingBugs]
     7 * '''Create the Patch File: '''
     8   * Get a fresh checkout of trunk or branch. See [wiki:DevelopersCorner#UsingSVN Using SVN] for information on how to check out the trunk or a branch.
     9   * Make your the modifications for your patch.
     10   * Run the tests until they all pass.
     11   * From a commandline, run {{{ svn diff > yourpatchname.patch }}} to create a patch file.
     12
     13 * '''Attach Patch to Ticket:''' Click the ''Attach File'' Button under the ''Attachments'' heading and select the {{{ yourpatchname.patch }}} file.
     14
     15 * '''Attach new files to Ticket:''' Files you have created as part of your change are not caught by the '''diff''' process. You will have to add these files individually to the patch.
     16
     17''For instructions on how to '''apply''' a patch, see ApplyingPatches''
