Changes between Version 4 and Version 5 of TracSearch
- May 8, 2022, 3:10:28 PM (2 years ago)
TracSearch
v4 v5 3 3 Trac has built-in search functionality to search for occurrences of keywords and substrings in wiki pages, tickets and changeset properties, such as author, revision and log messages. 4 4 5 Apart from the [search: Search module], you will also find a small search field above the navigation bar at all time. It provides convenient access to the search module from all pages.5 In addition to the [search: Search module], you will also find a small search field above the navigation bar. It provides convenient access to the search module from all pages. 6 6 7 The search results show the most recent modifications ranked first rather than the most relevant result.7 The search results show the most recent modifications ranked first. 8 8 9 9 == Quick searches 10 10 11 For quick access to project resources, the quick-search field at the top of every page can be used to enter a [TracLinks wiki link], which will take you directly to the resource identified by that link:11 For quick access to project resources, the quick-search field at the top of every page can be used to enter a [TracLinks TracLink], which will take you directly to the resource identified by that link: 12 12 13 13 * ![42] -- Opens change set 42 … … 21 21 == Search TracLinks 22 22 23 From the Wiki, it is possible to link to a specific search ,using `search:` links:24 * `search:?q=crash` will search for the string "crash" 23 From the Wiki, it is possible to link to a specific search using `search:` links: 24 * `search:?q=crash` will search for the string "crash" 25 25 * `search:?q=trac+link&wiki=on` will search for "trac" and "link" in wiki pages only 26 26 … … 30 30 31 31 ---- 32 See also: Trac Guide, TracLinks, TracQuery32 See also: TracLinks, TracQuery
