Changes between Version 3 and Version 4 of FdoSQLServerSpatialNotes
Show
03/18/08 08:16:47 (5 years ago)
gregboone
  • FdoSQLServerSpatialNotes
    v3 v4
    1111'''Setting up the provider.'''
    1212
    13 At this time, until we build an actual install tool, what we’re doing to set this up for !MapGuide 2009 and other clients is to edit the current providers.xml file and add a <!FeatureProvider> entry for SQL Server Spatial . Take the new dlls and drop them into the fdo bin directories for your client applications (e.g. C:\Program Files\Autodesk\!MapGuideEnterprise2009\Server\Bin\Fdo on my machine). Update the providers.xml file in those directories by adding the entry for the SQL Server Spatial provider.
     13At this time, until we build an actual install tool, what we’re doing to set this up for !MapGuide 2009 and other clients is to edit the current providers.xml file and add a <!FeatureProvider> entry for SQL Server Spatial . Take the new SQL Server Spatial Provider dlls and drop them into the fdo bin directory for your client applications (e.g. C:\Program Files\Autodesk\!MapGuideEnterprise2009\Server\Bin\Fdo on my machine). Once that is done, update the providers.xml file in those directories by adding the entry for the SQL Server Spatial provider.
    1414
    1515Here is the <!FeatureProvider> sectrion to add for SQL Server Spatial:
