Changes between Version 8 and Version 9 of FDORfc6
- Jul 22, 2007, 7:59:34 PM (17 years ago)
FDORfc6
v8 v9 47 47 3 new commands will be added to the FDO WMS Providers, individually for getting image formats, style and CS. The usage and the new classes and interfaces are listed as follows. 48 48 49 The following is an example of how WMS GetImageFormats command would be used to get the entire supported image formats list f orm WMS server after connection.49 The following is an example of how WMS GetImageFormats command would be used to get the entire supported image formats list from WMS server after connection. 50 50 {{{ 51 51 FdoPtr<FdoIGetImageFormats > cmd = static_cast<FdoIGetImageFormats *> (conn->CreateCommand (WmsCommandType_GetImageFormats)); … … 108 108 }}} 109 109 110 The following is an example of how WMS GetLayerStyles command would be used to get the entire supported image formats list f orm WMS server after connection.110 The following is an example of how WMS GetLayerStyles command would be used to get the entire supported image formats list from WMS server after connection. 111 111 {{{ 112 112 FdoPtr< FDOIGetLayerStyles > cmd = static_cast< FDOIGetLayerStyles *> (conn->CreateCommand (WmsCommandType_GetLayerStyles)); … … 204 204 }}} 205 205 206 The following is an example of how WMS GetLayerCRSNames command would be used to get the entire supported image formats list f orm WMS server after connection.206 The following is an example of how WMS GetLayerCRSNames command would be used to get the entire supported image formats list from WMS server after connection. 207 207 {{{ 208 208 FdoPtr<FdoIGetLayerCRSNames> cmd = static_cast<FdoIGetLayerCRSNames*> (conn->CreateCommand (FdoCommandType_GetLayerSupportedCRSNames));
