Changes between Version 5 and Version 6 of FDORfc30
Nov 19, 2008, 6:03:44 AM (15 years ago)
brentrobinson
  • FDORfc30
    v5 v6
    143143where:
    144144
    145 dataType – specifies the destination type. This parameter is only specified for FdoDataValue::Create(). For the other functions, the destination type is determined by the return type.
    146
    147 src – specifies the source type and value. It is converted to an FdoDataValue of the destination type.
    148
    149 nullIfIncompatible – determines what happens if the source and destination types are incompatible (e.g. pass FdoDataTimeValue as src to FdoBoolean::Create()):
    150
    151 true: returns a null FdoDataValue (FdoDataValue::IsNull() = true)
    152
    153 Note that the pointer returned is not null, the FdoDataValue returned has its null flag set
    154
    155 false: throw an exception.
    156
    157 shift – determines what happens if conversion would cause the value to change. This can happen when converting between numeric types and the destination type does not have enough precision to hold the value as is (e.g convert 1.9 from Double to Int32 ). Applicable only when both source and destination types are one of Byte, Decimal, Double, Int16, Int32, Int64 or Single:
    158
    159 true: shift the value by rounding it to the precision allowed by the destination type
    160 false: depends on the value of nullIfIncompatible:
    161
    162 true: return a null FdoDataValue (FdoDataValue::IsNull() = true). Note that the pointer returned is not null, the FdoDataValue returned has its null flag set
    163
    164 false: throw an exception
    165
    166 truncate – determines what happens if the value is outside the valid range for the destination type (e.g. convert 1000000 from FdoInt32Value to FdoInt16Value). Applicable only when both source and destination types are one of Boolean, Byte, Decimal, Double, Int16, Int32, Int64 or Single:
    167
    168 true: truncate the value to:
    169
    170 the maximum value for the destination type if the input value is greater than the maximum value
    171 the minimum value for the destination type if the input value is less than the minimum value
    172
    173 false: depends on the value of nullIfIncompatible:
    174
    175 true: return a null FdoDataValue (FdoDataValue::IsNull() = true). Note that the pointer returned is not null, the FdoDataValue returned has its null flag set
    176
    177 false: throw an exception
    178
    179 When the source type is numeric and the destination type is Boolean, the behaviour differs from the above and is as follows:
    180
    181 true: convert 0 to false and other values to true
    182 false: convert 0 to false and 1 to true. Throw an exception for other values
    183
    184 See the chart in the attached document for information on which pairs of types are compatible and which are incompatible.
    185
    186 Supporting Functions ¶
    187 The following function will be added:
    188
     145 '''dataType''' – specifies the destination type. This parameter is only specified for FdoDataValue::Create(). For the other functions, the destination type is determined by the return type.
     146
     147 '''src''' – specifies the source type and value. It is converted to an FdoDataValue of the destination type.
     148
     149 '''nullIfIncompatible''' – determines what happens if the source and destination types are incompatible (e.g. pass FdoDateTimeValue as src to FdoBoolean::Create()):
     150
     151  ''true'': returns a null FdoDataValue (FdoDataValue::IsNull() = true). Note that the pointer returned is not null, the FdoDataValue returned has its null flag set
     152
     153  ''false'': throw an exception.
     154
     155 '''shift''' – determines what happens if conversion would cause the value to change. This can happen when converting between numeric types and the destination type does not have enough precision to hold the value as is (e.g convert 1.9 from Double to Int32 ). Applicable only when both source and destination types are one of Byte, Decimal, Double, Int16, Int32, Int64 or Single:
     156
     157  ''true'': shift the value by rounding it to the precision allowed by the destination type
     158
     159  ''false'': depends on the value of nullIfIncompatible:
     160
     161   ''true'': return a null FdoDataValue (FdoDataValue::IsNull() = true). Note that the pointer returned is not null, the FdoDataValue returned has its null flag set
     162
     163   ''false'': throw an exception
     164
     165 '''truncate''' – determines what happens if the value is outside the valid range for the destination type (e.g. convert 1000000 from FdoInt32Value to FdoInt16Value). Applicable only when both source and destination types are one of Boolean, Byte, Decimal, Double, Int16, Int32, Int64 or Single:
     166
     167  ''true'': truncate the value to:
     168
     169   the maximum value for the destination type if the input value is greater than the maximum value
     170
     172
     173  ''false'': depends on the value of nullIfIncompatible:
     174
     175   ''true'': return a null FdoDataValue (FdoDataValue::IsNull() = true). Note that the pointer returned is not null, the FdoDataValue returned has its null flag set
     176
     177   ''false'': throw an exception
     178
     180
     181  ''true'': convert 0 to false and other values to true
     182
     183  ''false'': convert 0 to false and 1 to true. Throw an exception for other values
     184
     185 See the chart in the attached document for information on which pairs of types are compatible and which are incompatible.
     186
     187=== Supporting Functions ===
     188
     189The following functions will be added:
     190
     191{{{
    189192FDO_API FdoInt64 FdoStringP::ToInt64()
     193}}}
     194
    190195which converts a string to int64 value, and
    191196
     197{{{
    192198FDO_API FdoStringP::FdoStringP( FdoInt64 value )
    193 to convert an int64 to string. These functions hide the Win32 and Linux specific differences in doing these conversions.
    194
    195 T
     199}}}
     200
     201to convert an int64 to string. These functions hide the Windows and Linux specific differences in doing these conversions.
    196202
    197203== Implications ==
