Changes between Version 10 and Version 11 of FDORfc22
Sep 9, 2009 11:58:45 AM (10 years ago)
danstoica
  • FDORfc22
    v10 v11
    9696
    9797Autodesk to provide resurces / funding.
     98
     100== CORRECTION ==
     101FdoConcatFunction class doesn't extend FdoFunctionDefinition class. Therefore the new method FdoFunctionDefinition::SupportsVariableArgumentsList() is not virtual and the FdoFunctionDefinition constructors need to take an extra parameter.
     102
     103Therefore the correct changes are:
     104
     105FdoFunctionDefinition.h
     106{{{
     107class FdoFunctionDefinition : public FdoIDisposable
     108{
     109...
     110
     111public:
     112    /// \brief
     113    /// Indicates that this object allows its list of arguments to be variable so the
     114    /// last argument may be repeated.
     115    ///
     116    /// \return
     117    /// Returns true if the function allows a variable list of arguments and false otherwise.
     118    ///
     119
     120FDO_API bool FdoFunctionDefinition::SupportsVariableArgumentsList();
     121
     122/// Existing Create methods will take a new 'supportsVariableArgumentsList = false' input parameter.
     123
     124FDO_API static FdoFunctionDefinition *Create (FdoString                       *name,
     125                                                  FdoString                       *description,
     126                                                  FdoDataType                     returnType,
     127                                                  FdoArgumentDefinitionCollection *arguments,
     128                                                  FdoFunctionCategoryType         functionCategoryType = FdoFunctionCategoryType_Unspecified,
     129                                                  bool                            supportsVariableArgumentsList = false);
     130
     131// Similar for the other 2 Create methods...
     132}}}
     133
     134
