Changes between Version 18 and Version 19 of FDORfc20
Jun 13, 2008, 2:39:03 PM (16 years ago)
thomasknoell
  • FDORfc20
    v18 v19
    99||RFC Template Version||(1.0)||
    1010||Submission Date|| April 30, 2008 ||
    11 ||Last Modified|| Jack Lee [[Timestamp]]||
     11||Last Modified|| Thomas Knoell [[Timestamp]]||
    1212||Author||Thomas Knoell||
    1313||RFC Status||Draft||
    157157{{{
    158158
    159 public __gc __interface ICommandCapabilities : public System::IDisposable
     159public __gc __interface ICapability : public System::IDisposable
    160160{
    161161
    489489
    490490
    491 === Optimization ===
    492
    493 One use case was submitted that requested new capabilities to better control the building of a FDO filter. In this specific use case, the filter was build with multile use of the ''!FdoFilter::Combine()'' interface to combine different parts of a filter via the ''OR'' operation. The provided information described that the execution of a select command will fail on some providers if the number of those sub filters excceeds a certain limit. The request was for a new capability that would indicate how many sub-filters can be combined within a provider.
    494
    495 Investigation into this use case, however, showed that there is an issue with the process that transforms a filter to a SQL statement. If a node in the tree is reached that combines two sub-filters then the process does not look at the sub-filters to determine if it is required to nest them but rather goes ahead and nests them anyway. This way, the resulting SQL statement contains a deep nesting of sub filters. The following demonstrates this on a small scale:
    496
    497 {{{
    498
    499 Filter:
    500
    501   a = 1 or a = 2 or a = 3 or a = 4
    502
    503 Generated SQL statement:
    504
    505   ((((a = 1) or (a = 2)) or (a = 3)) or (a = 4))
    506
    507 }}}
    508
    509 Because of the highly nested SQL statement, some providers like ODBC and SQL Server may not be able to handle the complexity and issue an exception.
    510
    511 The nesting in general is valid but not always - like in the above example - necessary. This will be addressed as part of this RFC and optimized. The process will be modified to nest sub filters if this is not required. For the above example, this will result in the following SQL statement:
    512
    513 {{{
    514
    515 Filter:
    516
    517   a = 1 or a = 2 or a = 3 or a = 4
    518
    519 Generated SQL statement:
    520
    521   (a = 1) or (a = 2) or (a = 3) or (a = 4)
    522
    523 }}}
    524
    525 Once the nesting is eliminated the originally reported issue no longer appears. As a result there is no need for additional capabilities.
    526
    527
    528491== Test Plan ==
    529492
    530493Existing unit tests will be enhanced and new unit tests added to test all changes.
    531494
     495
    532496== Funding/Resources ==
    533497
