Changes between Version 18 and Version 19 of FDORfc16
- Mar 28, 2008, 10:12:35 AM (16 years ago)
FDORfc16
v18 v19 36 36 37 37 * well-defined subset of the geometry_columns table (as per SF spec, section 7.1.3.2, 7.1.3.3); see below for specific column requirements, 38 * spatial_ref_sys table (as per SF spec, section 7.1.2.2, 7.1.2.3) 38 * spatial_ref_sys table (as per SF spec, section 7.1.2.2, 7.1.2.3). Valid WKT spatial reference systems must be defined for each unique coordinate system used in the database. 39 39 * geometry_format column extending the geometry_columns table, set to one of WKB, WKT, WKB12, WKT12 or FGF. If not present, WKB will be assumed. 40 40 * one or more tables to store the geometry and associated features. Although in general [http://www.sqlite.org/datatype3.html type does not matter in SQLite], BLOB type is recommended at least for WKB and FGF formats as it does not perform character translation on the data.
