Changes between Initial Version and Version 1 of Ticket #607
- Jan 21, 2010, 7:37:19 AM (14 years ago)
Ticket #607 – Description
initial v1 3 3 http://62.214.147.252:8080/cgi-bin/mapserv.exe?map=C%3a%5cProgram+Files%5cms4w%5cApache%5chtdocs%5cBB2009%5cBB2009.map&version=1.1.1 4 4 5 Execute GetMap Request5 Execute a !GetMap Request 6 6 7 The WMS Server fails to return data from the GetMaprequest.7 The WMS Server fails to return data from the request. 8 8 9 Looking at the GetMaprequest and the reply from the WMS server. The WMS server replies with:9 Looking at the request and the reply from the WMS server. The WMS server replies with: 10 10 11 11 ‘msEvalRegex(): Regular expression error. String (C:\Program) failed expression test.? 12 12 13 and when looking in the GetMap request generated by Mapit looks like the path is not masked correctly. It should be: C%3a%5cProgram+Files%5cms4w%5cApache?but it looks like 'C:\Program Files\...? The space in the file name could be the cause of the issue - it should be masked correctly.13 When looking at the !GetMap request generated by the application, it looks like the path is not masked correctly. It should be: C%3a%5cProgram+Files%5cms4w%5cApache?but it looks like 'C:\Program Files\...? The space in the file name could be the cause of the issue - it should be masked correctly. 14 14
