Changes between Version 3 and Version 4 of WikiDeletePage
- May 8, 2022, 3:10:17 PM (2 years ago)
WikiDeletePage
v3 v4 7 7 Deleting specific versions or even complete pages can make sense to remove spam or other abusive submissions. 8 8 9 However, if you want to delete a page because you re-created a new page with the same content but a different name, it is recommended to keep the page and use it as a redirection page instead of completely deleting it. This will avoid frustrating the visitor with broken links, particularly when coming to the site from a search engine. 9 However, if you want to delete a page because you re-created a new page with the same content but a different name, it is recommended to keep the page and use it as a redirection page instead of completely deleting it. This will avoid frustrating the visitor with broken links, particularly when coming to the site from a search engine. 10 10 11 In this situation, chances are that you actually wanted to [[WikiNewPage#renaming|rename]] the page instead of doing a copy and delete. 11 In this situation, chances are that you actually wanted to [[WikiNewPage#renaming|rename]] the page instead of doing a copy and delete. 12 12 The //Rename// operation offers you the possibility to create a redirection page. 13 A redirection page is a short page that contains a link such as “See !SomeOtherPage”. 13 A redirection page is a short page that contains a link such as “See !SomeOtherPage”. 14 14 15 15 ----
