Changes between Version 2 and Version 3 of TracWiki
- Feb 1, 2017, 12:33:48 AM (7 years ago)
TracWiki
v2 v3 2 2 [[TracGuideToc]] 3 3 4 Trac has a built-in wiki system which you can use for organizing knowledge and information in a very flexible way by [WikiNewPage creating pages] containing an intuitive and easy to learn textual markup. Th is text markup is also used in all other parts of the system, not only in [wiki:TitleIndex wiki pages], but also in [wiki:TracTickets ticket] description and comments, [wiki:TracChangeset check-in log messages], [wiki:TracRoadmap milestone] descriptions and [wiki:TracReports report] descriptions,even in third-party extensions.4 Trac has a built-in wiki system which you can use for organizing knowledge and information in a very flexible way by [WikiNewPage creating pages] containing an intuitive and easy to learn textual markup. The wiki markup is used throughout Trac, so not only in [wiki:TitleIndex wiki pages], but also in [TracTickets ticket] description and comments, [TracChangeset version control] log messages, [TracRoadmap milestone] descriptions, [TracReports report] descriptions and even in third-party extensions. 5 5 It allows for formatted text and hyperlinks in and between all Trac modules. 6 6 7 Editing wiki text is easy, using any web browser and a simple [WikiFormatting formatting system], rather than more complex markup languages like HTML. The reasoning behind its design is that HTML, with its large collection of nestable tags, is too complicated to allow fast-paced editing, and distracts from the actual content of the pages. Note though that Trac also supports [WikiHtml HTML], [WikiRestructuredText reStructuredText] and [http://www.textism.com/tools/textile/ Textile] as alternative markup formats, which can eventually be used in parts of a page (so called wiki “blocks”).7 Editing wiki text is easy, as compared to complex markup languages like HTML, using any web browser and simple [WikiFormatting formatting]. The motivation for wiki markup is that HTML, with its large collection of nestable tags, is too complicated to allow fast-paced editing, and distracts from the actual content of the pages. Note that Trac also supports [WikiHtml HTML], [WikiRestructuredText reStructuredText] and [https://txstyle.org Textile] as alternative markup formats, which can be used in parts of a page, so called wiki blocks. 8 8 9 The main goal of the wiki is to make editing text eas ier and ''encourage'' people to contribute and annotate text content fora project. Trac also provides a simple toolbar to make formatting text even easier, and supports the [http://universaleditbutton.org/Universal_Edit_Button universal edit button] of your browser.9 The main goal of the wiki is to make editing text easy in order to ''encourage'' people to contribute to a project. Trac also provides a simple toolbar to make formatting text even easier, and supports the [http://universaleditbutton.org/Universal_Edit_Button universal edit button] of your browser. 10 10 11 11 The wiki itself does not enforce any structure, but rather resembles a stack of empty sheets of paper, where you can organize information and documentation as you see fit, and later reorganize if necessary. 12 As contributing to a wiki is essentially building hypertext, 13 general advice regarding HTML authoring apply here as well. 14 For example, the ''[http://www.w3.org/Provider/Style Style Guide for online hypertext]'' explains how to think about the 15 [http://www.w3.org/Provider/Style/Structure.html overall structure of a work] 16 and how to organize information [http://www.w3.org/Provider/Style/WithinDocument.html within each document]. One of the most important tips is “make your HTML page such that you can read it even if you don't follow any links.” 12 As contributing to a wiki is essentially building hypertext, general advice regarding HTML authoring apply here as well. 13 For example, the ''[https://www.w3.org/Provider/Style Style Guide for online hypertext]'' explains how to think about the [https://www.w3.org/Provider/Style/Structure.html overall structure of a work] and how to organize information [https://www.w3.org/Provider/Style/WithinDocument.html within each document]. One of the most important tips is to "make your HTML page such that you can read it, even if you don't follow any links". 17 14 18 15 Learn more about: 19 * WikiFormatting rules, including advanced topics like WikiMacros and WikiProcessors 20 * How to use WikiPageNames and other forms of TracLinks which are used to refer in a precise way to any resource within Trac16 * WikiFormatting rules, including advanced topics like WikiMacros and WikiProcessors. 17 * How to use WikiPageNames and other forms of TracLinks which are used to refer to any resource within Trac. 21 18 22 If you want to practice editing, please use the SandBox. Note that not all Trac wiki s are editable by anyone, this depends on the local policy; check with your Trac administrators.19 If you want to practice editing, please use the SandBox. Note that not all Trac wiki pages are editable by anyone, this depends on the local policy; check with your Trac administrators. 23 20 24 Before saving your changes, you can ''Preview'' the page or ''Review the Changes'' you've made.25 You can get an automatic preview of the formatting as you type when you activate the ''Edit Side-by-side'' mode (you have to Preview the page for the setting to take effect). '' There is a [wiki:/TracIni#trac-section configurable delay] between when you make your edit and when the automatic preview will update.''21 Before saving your changes, you can ''Preview'' the page or ''Review Changes'' you have made. 22 You can get an automatic preview of the formatting as you type when you activate the ''Edit Side-by-side'' mode. There is a [wiki:TracIni#/auto_preview_timeout configurable delay] between when you make your edit and when the automatic preview will update. 26 23 27 24 Some more information about wikis on the web: 28 * A definition of [http ://wikipedia.org/wiki/Wiki Wiki], in a famous wiki encyclopedia29 * The [http://c2.com/cgi/wiki?WikiHistory History] of the original wiki30 * A wiki page explaining [http://www.usemod.com/cgi-bin/mb.pl?WhyWikiWorks why wiki works] 25 * A definition of [https://wikipedia.org/wiki/Wiki Wiki] according to Wikipedia. 26 * The [http://c2.com/cgi/wiki?WikiHistory history] behind the original wiki. 27 * A wiki page explaining [http://www.usemod.com/cgi-bin/mb.pl?WhyWikiWorks why wiki works]. 31 28 32 29 ----
