Changes between Version 3 and Version 4 of TracModWSGI
- May 8, 2022, 3:10:12 PM (2 years ago)
TracModWSGI
v3 v4 7 7 == The `trac.wsgi` script 8 8 9 Trac can be run on top of mod_wsgi with the help of an application script, which is a Python file saved with a `.wsgi` extension. 9 Trac can be run on top of mod_wsgi with the help of an application script, which is a Python file saved with a `.wsgi` extension. 10 10 11 11 A robust and generic version of this file can be created using the `trac-admin <env> deploy <dir>` command which automatically substitutes the required paths, see TracInstall#cgi-bin. The script should be sufficient for most installations and users not wanting more information can proceed to [#Mappingrequeststothescript configuring Apache]. 12 12 13 If you are using Trac with multiple projects, you can specify their common parent directory using the `TRAC_ENV_PARENT_DIR` in trac.wsgi:13 If you are using Trac with multiple projects, you can specify their common parent directory in `trac.wsgi`: 14 14 {{{#!python 15 15 def application(environ, start_request): 16 # Add this to configwhen you have multiple projects17 environ.setdefault('trac.env_parent_dir', '/usr/share/trac/projects') 16 # Add this when you have multiple projects 17 environ.setdefault('trac.env_parent_dir', '/usr/share/trac/projects') 18 18 .. 19 19 }}} 20 21 Directories residing in `trac.env_parent_dir` that are not environment directories will display an error message on the [TracInterfaceCustomization#ProjectList project index page]. The directories can be excluded by listing them in a `.tracignore` file residing in `trac.env_parent_dir`. Unix [https://docs.python.org/2/library/fnmatch.html shell-style wildcard patterns] can be used in the newline separated list of directories. 20 22 21 23 === A very basic script … … 47 49 === A more elaborate script 48 50 49 If you are using multiple `.wsgi` files (for example one per Trac environment) you must ''not'' use `os.environ['TRAC_ENV']` to set the path to the Trac environment. Using this method may lead to Trac delivering the content of another Trac environment, as the variable may be filled with the path of a previously viewed Trac environment. 51 If you are using multiple `.wsgi` files (for example one per Trac environment) you must ''not'' use `os.environ['TRAC_ENV']` to set the path to the Trac environment. Using this method may lead to Trac delivering the content of another Trac environment, as the variable may be filled with the path of a previously viewed Trac environment. 50 52 51 53 To solve this problem, use the following `.wsgi` file instead: … … 57 59 import trac.web.main 58 60 def application(environ, start_response): 59 environ['trac.env_path'] = '/usr/local/trac/mysite' 61 environ['trac.env_path'] = '/usr/local/trac/mysite' 60 62 return trac.web.main.dispatch_request(environ, start_response) 61 63 }}} 62 64 63 For clarity, you should give this file a `.wsgi` extension. You should probably put the file in its own directory, since you will expose it to Apache. 65 For clarity, you should give this file a `.wsgi` extension. You should probably put the file in its own directory, since you will expose it to Apache. 64 66 65 67 If you have installed Trac and Python eggs in a path different from the standard one, you should add that path by adding the following code at the top of the wsgi script: … … 128 130 == Configuring Authentication 129 131 130 The following sections describe different methods for setting up authentication. See also [http ://httpd.apache.org/docs/2.4/howto/auth.html Authentication, Authorization and Access Control] in the Apache guide.132 The following sections describe different methods for setting up authentication. See also [https://httpd.apache.org/docs/2.4/howto/auth.html Authentication, Authorization and Access Control] in the Apache guide. 131 133 132 134 === Using Basic Authentication … … 206 208 See also the [https://httpd.apache.org/docs/2.4/mod/mod_auth_basic.html mod_auth_digest] documentation. 207 209 208 === Using LDAP Authentication 210 === Using LDAP Authentication 209 211 210 212 Configuration for [https://httpd.apache.org/docs/2.4/mod/mod_ldap.html mod_ldap] authentication in Apache is more involved (httpd 2.2+ and OpenLDAP: slapd 2.3.19). … … 266 268 267 269 See also: 268 - [https://httpd.apache.org/docs/2.4/mod/mod_authnz_ldap.html mod_authnz_ldap], documentation for mod_authnz_ldap. 270 - [https://httpd.apache.org/docs/2.4/mod/mod_authnz_ldap.html mod_authnz_ldap], documentation for mod_authnz_ldap. 269 271 - [https://httpd.apache.org/docs/2.4/mod/mod_ldap.html mod_ldap], documentation for mod_ldap, which provides connection pooling and a shared cache. 270 272 - [https://trac-hacks.org/wiki/LdapPlugin TracHacks:LdapPlugin] for storing TracPermissions in LDAP. … … 272 274 === Using SSPI Authentication 273 275 274 If you are using Apache on Windows, you can use mod_auth_sspi to provide single-sign-on. Download the module from the !SourceForge [http ://sourceforge.net/projects/mod-auth-sspi/ mod-auth-sspi project] and then add the following to your !VirtualHost:276 If you are using Apache on Windows, you can use mod_auth_sspi to provide single-sign-on. Download the module from the !SourceForge [https://sourceforge.net/projects/mod-auth-sspi/ mod-auth-sspi project] and then add the following to your !VirtualHost: 275 277 {{{#!apache 276 278 <Location /trac/login> … … 308 310 309 311 {{{#!python 310 def application(environ, start_request): 311 # Set authenticated username on CA SiteMinder to REMOTE_USER variable 312 def application(environ, start_request): 313 # Set authenticated username on CA SiteMinder to REMOTE_USER variable 312 314 # strip() is used to remove any spaces on the end of the string 313 if 'HTTP_SM_USER' in environ: 315 if 'HTTP_SM_USER' in environ: 314 316 environ['REMOTE_USER'] = environ['HTTP_REMOTE_USER'].strip() 315 317 ... … … 367 369 Please use either version 1.6, 2.4 or later of `mod_wsgi`. Versions prior to 2.4 in the 2.X branch have problems with some Apache configurations that use WSGI file wrapper extension. This extension is used in Trac to serve up attachments and static media files such as style sheets. If you are affected by this problem, attachments will appear to be empty and formatting of HTML pages will appear not to work due to style sheet files not loading properly. Another frequent symptom is that binary attachment downloads are truncated. See mod_wsgi tickets [https://code.google.com/archive/p/modwsgi/issues/100 #100] and [https://code.google.com/archive/p/modwsgi/issues/132 #132]. 368 370 369 '''Note''': using mod_wsgi 2.5 and Python 2.6.1 gave an Internal Server Error on my system (Apache 2.2.11 and Trac 0.11.2.1). Upgrading to Python 2.6.2 (as suggested [http ://www.mail-archive.com/modwsgi@googlegroups.com/msg01917.html here]) solved this for me[[BR]]-- Graham Shanks371 '''Note''': using mod_wsgi 2.5 and Python 2.6.1 gave an Internal Server Error on my system (Apache 2.2.11 and Trac 0.11.2.1). Upgrading to Python 2.6.2 (as suggested [https://www.mail-archive.com/modwsgi@googlegroups.com/msg01917.html here]) solved this for me[[BR]]-- Graham Shanks 370 372 371 373 If you plan to use `mod_wsgi` in embedded mode on Windows or with the MPM worker on Linux, then you will need version 3.4 or greater. See [trac:#10675] for details. … … 413 415 //This is not a recommended approach though. See also the notes at the bottom of the [https://code.google.com/archive/p/modwsgi/wikis/IntegrationWithTrac.wiki mod_wsgi's IntegrationWithTrac] wiki page.// 414 416 415 === Missing Headers and Footers416 417 If python optimizations are enabled, then headers and footers will not be rendered. An error will be raised in Trac 1.0.11 and later when optimizations are enabled.418 419 In your WSGI configuration file, the `WSGIPythonOptimize` setting must be set to `0` (`1` or `2` will not work):420 421 {{{#!apache422 WSGIPythonOptimize 0423 }}}424 425 On Ubuntu, the WSGI mod configuration is at `/etc/apache2/mods-enabled/wsgi.conf`.426 427 The same issue is seen with `PythonOptimize On` in [TracModPython#Pagelayoutissues ModPython].428 429 417 === Other resources 430 418
